Open Source Hardware
Blog My 2017 Projects/Activities
  • Author Author: shabaz
  • Date Created: 22 Dec 2017 6:53 PM Date Created
  • Views 3300 views
  • Likes 16 likes
  • Comments 10 comments
shabaz
shabaz
22 Dec 2017
2017 was a busy year, I had a lot of personal stuff to do, but there was lots of engineering related stuff going on too, and I enjoyed seeing what everyone was working on. This blog post lists the activities I worked on.
  Project/Activity
Description
1Make your own Test Leads; Assembling 4mm Banana PlugsI started off the year making some banana test leads!image
2Raspberry Pi 3 Block DiagramIt was followed by an attempt to build a block diagram of the Raspberry Pi 3 since I couldn't find one online.image
3Low Cost PCBs - What Can They Look Like?Exploring printed circuit boards under a microscopeimage
4Cisco Live 2017 in BerlinSome photos from the Cisco Live event in Berlinimage
5
Embedded World 2017 – Getting Ready!
Embedded World 2017 - (part of) Day 1
Embedded World 2017 - Day 1 continued
Embedded World 2017 - Day 2!
A trip to Embedded World in Nuremberg, thanks to element14image
6A New Ruggedized Raspberry Pi 3 –  netPI!A report on the netPI at Embedded Worldimage
7Robots - Science Museum London ExhibitionThe Robots exhibition that was running at the Science Museum, Londonimage
8Get Started Coding with Raspberry Pi LibraryAn ongoing series of articles on Coding with the Pi for complete beginnersimage
9Building a Software Defined Radio (SDR) with LimeSDRWork on turning a software defined radio circuit board (called LimeSDR) into a usable productimage
10Building a USB Keypad: A Mini-ProjectA USB keypad for computers; it can be used for keyboard shortcuts, or as a numeric keypad or games keypad for a PC or Pi for instanceimage
11Google's Alexa-like Pi AIY Kit, mini teardownA teardown/reverse-engineering exercise on the Google AIY kitimage
12Fake and Re-used Electronic Parts and ComponentsA brief discussion about peoples experiences with fake/used componentsimage
13Cyclops-1000: An Electronic Eye for Rotational Speed MeasurementA handheld RPM meter/tachometer style project, suitable for beginners; part of a fun series called Project14image
14
Home Automation in the UK Simplified, Part 1: Energenie MiHome
Home Automation in the UK Simplified, Part 2: Raspberry Pi and Touch Display
A couple of reports on home automation and how to control and monitor it all from a Piimage
15Build your own Torch/Flashlight!A Project14 torch/flashlight project. It is ongoing, I have received the printed circuit boards from the factory now.image
16Five scenarios where TI Power Supply circuits came to the rescueA discussion about five power supply circuits including an iPhone/iPod charger and a LiPo cell chargerimage
17Building a Solar ChargerA Project14 solar charger project. This is a work-in-progress, PCB still to be laid outimage
18Building a Linear Power Supply ModuleA dual (or triple) rail power supply project intended for op-amp/headphone audio projectsimage
19Soldering Surface Mount Exposed Die Pads with an IronHow to solder parts with an exposed pad on the underside, using a normal soldering ironimage
20Building a Low Cost Solder Fume Extractor – Part 1DIY solder fume extractor based on an array of PC fans and some filtersimage
21DMX Explained; DMX512 and RS-485 Protocol Detail for Lighting ApplicationsA lighting protocol (DMX512) was examinedimage
22Working with FRDM Boards and ARM mbedA step-by-step guide to working with an online microcontroller development environment called ARM mbed and a range of Arduino-like boards from NXPimage
23Building a Fluxgate Magnetometer based Current ProbeThis project was a lot of fun - building a current sensor with a very interesting sensor. It was also useful for seeing the seconds ticking from a wristwatch!image
24Building a Three Phase Mains Power System SimulatorA project that simulates a three-phase industrial supply; this is useful for examining the electrical relationship per phase and between phases, using an oscilloscope or multimeterimage
25Proxxon Rotary Tools Review: Micromot 50/EF, FBS 12/EF and NG 2/EThere are a bunch of high-speed rotary tools from Proxxon; I examined a couple of them, and the power transformer. Also an investigation into speeds/feeds for drilling and milling with small diameter toolsimage
26Panasonic Grid-EYE RoadTest - ReviewThe Grid-EYE is an interesting sensor; it can perform thermal imaging and is ideal for people/occupancy detection purposes. This was a review of the Grid-EYE evaluation boardimage
27MAXREFDES143#: DeepCover Embedded Security in IoT - ReviewAn examination of a security chip that can be used for creating 'authentic' hardware peripheralsimage
28Programmable DC Electronic Loads with the BK8600 - ReviewA review of a DC Electronic Load. It was used to examine solar panels, supercapacitors and it was used to investigate high power LEDs using a voltage sourceimage
29Texas Instruments FDC2214 Capacitance to Digital - ReviewAn examination of a very unique integrated circuit from Texas Instruments. It can measure capacitance with a high level of stability. It was used to build a prototype dust sensorimage
30RoadTest the Keysight U1282A Digital Multimeter - ReviewA review of the best handheld multimeters I've ever used. It has an extraordinary set of functionality, and is on balance perhaps the most accurate multimeter too, across most ranges, across the important part of the ranges. I used it for a lot of experiments - the remote Bluetooth capability is excellent.image
31SILICON LABS USB-TO-UART Bridge Controller EVM - ReviewThe Silicon Labs CP2102N USB-to-UART integrated circuit was reviewed; it was used to explore USB chargers, and to construct a MIDI interface for musical instrumentsimage
32Megger Insulation Tester - ReviewI got to explore a technology that was new to me; insulation resistance measurement. It is used to diagnose various electrical problems with machines. I used it to examine a very old ringer from a telephoneimage
33Wireless Power Design Kit - Medium Power - ReviewWireless power was another new technology for me; the Wurth/Rohm design kit supports up to 15W of power which makes it a lot more compelling for products that could take ages to charge with the earlier 5W wireless power standard.image
34Experimenting with E-Paper Displays: Building a Clock! A really simple project to build a clock; mainly to explore e-paper displays!image
    shabaz over 8 years ago in reply to jw0752
    Thanks Rachael and everyone, I loved checking out all the stuff you worked on this year too, and looking forward to the next year. This place would not be the same without you guys!!
  • ciorga
    ciorga over 8 years ago
    Well done Shabaz! I am impressed of how many activities you have involved with and of all your achievements this year.
    Cosmin
    jw0752 over 8 years ago in reply to mcb1
    Hi Mark,
    Let's not mess with what is working.
    mcb1 over 8 years ago in reply to rachaelp
    Seriously duud we need to find you a hobby ... one that doesn't involve electronics. image
    Well done
    • Vote Up +6 Vote Down
  • rachaelp
    rachaelp over 8 years ago
    34 Projects! 34!!! I knew you'd done a lot but that's awesome! As always you've set the bar very high for the rest of us! image
