FPGA
FPGA
Blog Learning Xilinx Zynq: FPGA based PWM generator with scroll wheel control
  • Date Created: 9 Jul 2021 2:32 PM Date Created
  • Views 9926 views
  • Likes 15 likes
  • Comments 6 comments
  • summer_of_fpgas
  • diytestinstrumentationch
  • fpga_projects
  • summer_of_fpga
9 Jul 2021
DIY Test Instrumentation        Submit an EntrySubmit an Entry
Monthly Themes  | Monthly Poll  |  Back to homepage image
This DIY instrument is a PWM generator with dead band support.
It has 2 complementary outputs and supports dead time. It can safely drive a (GaN) half bridge.
Specifications
  • PWM with fixed frequency: 1.5625 MHz
  • Duty cycle: 6 bits (64 steps)
  • Dead band: 0 - 150 ns, 4 bits (16 steps of 10 ns)
  • Duty cycle variable, controlled with scroll wheel
  • Dead band programmable from a browser
  • Duty cycle display on a progress bar in a browser
Design
This DIY instrument is the outcome of a blog series I wrote while I was learning Vivado and the Xilinq Zynq FPGA.
These are the FPGA modules, and a link to the post where I started the design:
  • VHDL PWM with dead band
  • VHDL quadrature decoder to read the scroll wheel
  • Vivado design with memory mapped registers to exchange data between Linux and FPGA fabric
It's the first time I use a hierarchical block diagram. The decoder and PWM components are in the dark blue block in the image above (click to enlarge).
Here is the detail:
VHDL PWM source
Thank you: http://www.xess.com/
Latest source on github: https://gist.github.com/jancumps/36f21e89bfb8e44f3dba7bf014ffd198
-- Module for generating repetitive pulses.
library IEEE;
use IEEE.std_logic_1164.all;
package PulsePckg is
  constant HI   : std_logic := '1';
  constant LO   : std_logic := '0';
  constant ONE  : std_logic := '1';
end package;
-- PWM module.
library IEEE;
use IEEE.MATH_REAL.all;
use IEEE.numeric_std.all;
use WORK.PulsePckg.all;
entity Pwm is
  port (
    n_reset_i : in  std_logic;          -- async reset
    clk_i  : in  std_logic;             -- Input clock.
    duty_i : in  std_logic_vector (5 downto 0);      -- Duty-cycle input.
    band_i : in  std_logic_vector (3 downto 0);      -- number of clock-ticks to keep both signals low before rising edge
    pwmA_o  : out std_logic;            -- PWM output.
    pwmB_o  : out std_logic             -- PWM output inverse.
end entity;
architecture arch of Pwm is
  signal timer_r       : natural range 0 to 2**duty_i'length-1;
begin
  clocked: process(clk_i, n_reset_i)
  begin
    pwmA_o   <= LO;
    pwmB_o   <= LO;
    -- async reset
    if n_reset_i = '0' then
        timer_r <= 0;
    elsif rising_edge(clk_i) then
      -- timer
      timer_r <= timer_r + 1;
      -- output a
      if timer_r < unsigned(duty_i) and timer_r >= unsigned(band_i)  then
        pwmA_o <= HI;
      end if;
      -- output b
      if timer_r >= to_integer(unsigned(band_i)) + to_integer(unsigned(duty_i)) then
        pwmB_o <= HI;
      end if;
    end if; -- rising_edge
  end process clocked;
end architecture;
VHDL Quadrature Decoder source
thank you: https://www.hackmeister.dk/2010/07/using-a-quadrature-encoder-as-input-to-fpga/
Latest source on github: https://gist.github.com/jancumps/0f89b68d961d969665e60b653de94e8a
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity quadrature_decoder is
    Port ( QuadA : in  STD_LOGIC;
           QuadB : in  STD_LOGIC;
           Clk : in  STD_LOGIC;
           nReset : in STD_LOGIC;
           Position : out  unsigned (5 downto 0));
end quadrature_decoder;
architecture Behavioral of quadrature_decoder is
signal QuadA_Delayed: std_logic_vector(2 downto 0) := (others=>'0');
signal QuadB_Delayed: std_logic_vector(2 downto 0) := (others=>'0');
signal Count_Enable: STD_LOGIC;
signal Count_Direction: STD_LOGIC;
-- signal Count: unsigned(5 downto 0) := "000000";
signal Count: unsigned(Position'length-1 downto 0) := (others=>'0');
begin
process (Clk, nReset)
begin
   if (nReset = '0') then
      Count <= (others=>'0');
      QuadA_Delayed <= (others=>'0');
      QuadB_Delayed <= (others=>'0');
   elsif rising_edge(Clk) then
      QuadA_Delayed <= (QuadA_Delayed(1), QuadA_Delayed(0), QuadA);
      QuadB_Delayed <= (QuadB_Delayed(1), QuadB_Delayed(0), QuadB);
      if Count_Enable='1' then
         if Count_Direction='1' then
            Count <= Count + 1;
            Position <= Count;
         else
            Count <= Count - 1;
            Position <= Count;
         end if;
      end if;
   end if;
end process;
Count_Enable <= QuadA_Delayed(1) xor QuadA_Delayed(2) xor QuadB_Delayed(1)
            xor QuadB_Delayed(2);
Count_Direction <= QuadA_Delayed(1) xor QuadB_Delayed(2);
end Behavioral;
PYNQ and Jupyter Notebook integration
The quadrature decoder output is directly routed to the PWM module, without software interference.
Additionally, this value is memory mapped to the Linux part of the ZYNQ 7. It can be read out in a user space program.
For this project, I show it in a browser on a Jupyter notebook:
The same notebook is used to load the Vivado design into the FPGA and to set the dead band.
The Vivado project with all sources, and the Jupyter notebook, are attached to this post.
Hardware
Real world example: Control a GaN half-bridge that needs 8-10 ns dead band between upper and lower FET
Video: the design in action:
I documented my learning path, starting the day after I got the board as a present from balearicdynamics on May 30, when we visited the Drongen maker space:
Pynq - Zync - Vivado series
Add Pynq-Z2 board to Vivado
Learning Xilinx Zynq: port a Spartan 6 PWM example to Pynq
Learning Xilinx Zynq: use AXI with a VHDL example in Pynq
VHDL PWM generator with dead time: the design
Learning Xilinx Zynq: use AXI and MMIO with a VHDL example in Pynq
Learning Xilinx Zynq: port Rotary Decoder from Spartan 6 to Vivado and PYNQ
Learning Xilinx Zynq: use RAM design for Altera Cyclone on Vivado and PYNQ
Learning Xilinx Zynq: a Quadrature Oscillator - 2 implementations
Learning Xilinx Zynq: a Quadrature Oscillator - variable frequency
Learning Xilinx Zynq: Hardware Accelerated Software
Automate Repeatable Steps in Vivado
Learning Xilinx Zynq: Try to make my own Accelerated OpenCV Function - 1: Vitis HLS
Learning Xilinx Zynq: Try to make my own Accelerated OpenCV Function - 2: Vivado Block Design
Learning Xilinx Zynq: Logic Gates in Vivado
Learning Xilinx Zynq: Interrupt ARM from FPGA fabric
Learning Xilinx Zynq: reuse and combine components to build a multiplexer
PYNQ version 2.7 (Austin) is released
PYNQ and Zynq: the Vitis HLS Accelerator with DMA training - Part 1: Turn C++ code into an FPGA IP
PYNQ and Zynq: the Vitis HLS Accelerator with DMA training - Part 2: Add the Accelerated IP to a Vivado design
PYNQ and Zynq: the Vitis HLS Accelerator with DMA training - Part 3: Use the Hardware Accelerated Code in Software
PYNQ and Zynq: the Vitis HLS Accelerator with DMA training - Deep Dive: the data streams between Accelerator IP and ARM processors
Use the ZYNQ XADC with DMA part 1: bare metal
Use the ZYNQ XADC with DMA part 2: get and show samples in PYNQ
VHDL: Convert a Fixed Module into a Generic Module for Reuse
jupyter_notebook.zip
quad_pwm.zip
    Jan Cumps over 5 years ago +3
    I've been looking at other people's AXI (memory map) implementation, and I see I have an error in all my AXI designs: I connected the processor's interconnect_axi reset to all my resets, but it is only…
    Jan Cumps over 5 years ago +1
    I've added a second video, with the FPGA PWM actually driving a home-made GaN half bridge. www.youtube.com/watch
    Jan Cumps over 3 years ago in reply to Jan Cumps
    I got the simple example working again - that's a start Slight smile
    It's been so long ago that I completely forgot how Pynq and Jupiter work. Reading my own post  Learning Xilinx Zynq: port a Spartan 6 PWM example to Pynq
    Jan Cumps over 3 years ago in reply to yepe
    It's been a while since I've seen my own code. I'm trying if I can make the project work again...
    I think that the easiest way to achieve this, as beginner, is to eat the elephant in pieces. Ignore my code, because it's not the basis for what you need.
    • make a design that can generate the clock. Confirm by probing.
    • make a design that can generate one of the easy signals, based on that clock. PWM maybe? If you can make that clock at 10 kHz, you know that you'll be able to generate the slower ones too
    • add PWMN to the design. That should be easy, because it's NOT PWM
    • try a separate design with the PRF logic. If you have that working, add to the original one (or keep separate, feeding it from the same clock?)
    • same for the remaining ones.
    The advantage of little steps is that you'll get early success, and that boosts the morale.
    Advantage of separate blocks for a beginner is that the code stays separate and graspable.
    The main job for each signal will will be to:
    • find out after how many ticks of the clock the signal should change
    • count the clock ticks and compare it to the figure(s) figured out above
    • set the output(s) to the desired state.
  • yepe
    yepe over 3 years ago
    Hi Jan Cumps, I hope you don't mind if I ask a question regarding the PYNQ half-bridge PWM driver. I am working on a student project for school and I need to drive a half-bridge for an ultrasound pulser. I was working through your great tutorial and I had the complementary pwm output on my board PYNQ Z1. However, I have to make certain changes to the operation to make it compatible with my needs which I attempted to do, but I could not determine the best approach. First off, I need to simplify that I only need 50% duty cycle and no other duty cycles needed. I have made a timing diagram for the various waveforms:
    CLK should be a continuous 20 MHz signal, PRF should be a 10 kHz 50% duty cycle signal that synchronizes the rest of the waveforms. PWM&PWMN are the complementary PWM signals with dead-time of programmable N cycles with a timed delay from a falling edge of PRF. PULSE should be equal to the length of the PWM pulse train, and GATE is equal to pulse but with a programmable delay. The PWM pulse-train should be 5 MHz. The first thing I tried to do is to change your example to see if I could get a 5 MHz complementary PWM but I could not see how the frequency is determined so I was playing around with the board clocks and only could get it up to 650 kHz.
    I am a biginner at vhdl so I am a bit out of my element. I have developed all the electronics and analogue demodulation circuits but I still lack the control system to tie it together. If I were to implement these signals in the PYNQ, where do you propose to start?
