FPGA
FPGA
Blog Learning Xilinx Zynq: use RAM design for Altera Cyclone on Vivado and PYNQ
  • Date Created: 2 Aug 2021 5:03 PM Date Created
  • Views 3675 views
  • zynq
  • pinq
  • xilinx
  • fpga
  • vivado
  • vhdl
  • automated_test_applications
2 Aug 2021
Store 1024 12 bit values in a VHDL RAM design, and automatically test it.
This post uses the VHDL RAM design of Michael Kellett on a Zynq. You can store data and read it back.
The design was done out of curiousity. To see how and when Block RAM slices are used. Check the discussions in the comments of MKs post.
Here, I just focus on how the exercise is done with Vivado, Zynq and Pynq.
If this blog proves anything, it's that HDL is very portable.
VHDL Memory component
VHDL source of the memory design is exactly the same as Michael's, except that his block holds 64 12 bit values, mine 1024.
That's why I changed:
  • the name from mem_inf_sp_64_12 to mem_inf_sp_1024_12
  • the address from STD_LOGIC_VECTOR(5 downto 0) to STD_LOGIC_VECTOR(9 downto 0). It has to fit the 1024 values instead of 64
  • the array of data from array (0 to 63) to array (0 to 1023)
Latest source on github: https://gist.github.com/jancumps/72f319d33200af69d823701005e9d9cb
ZYNQ integration between FPGA and ARM / Linux
These signals will come from the ARM / Linux side
  • we: write enable. I use a GPIO for that
  • en: enable. Also a GPIO
  • address: address to read from or write to the memory. 10 MSB of a AXI memory mapped register
  • data: data to write. 12 LSB of that same AXI memory mapped register.
  • the clock
When a read is requested, the FPGA will send this back to ARM / Linux:
  • data: the value present at address when a read is requested. 12 LSB of that same memory mapped register.
Block Design
I've kept it as simple as I could. Just enough to provide the interfaces described in the previous section.
I'm going to skip explaining the mechanics but will show the configs. Every technique has been used before in this blog series.
click to enlarge
The green block is Michael's Memory module. In the block design, I linked all inputs and outputs to the ARM / Linux interfaces.
For the technology used for each signal between ARM and fabric, see the section above.
Configuration
ARM
Zynq AXI for Data and Address register
Zynq GPIO for Enable and Write Enable
Data and address (AXI)
AXI Interconnect
AXI GPIO
Address slice
Isolates the 10 Address bits out of a 32 bit AXI memory mapped register
Write Data slice
Isolates the 12 Data bits out of a 32 bit AXI memory mapped register
Read Data left-padded with 0
Concatenate (left pad) 10 '0' bits to the 12 data bits data, to fill all bits of the 22 bit wide AXI register
The constant 10 '0' bits
Enable and Write Enable (GPIO)
Enable slice
Isolates the Enable bit out of the 64 bit GPIO interface
Write Enable slice
Isolates the Write Enable bit out of the 64 bit GPIO interface
All of these blocks tie to the VHDL memory block. You'll see that the bit width and directions match.
Test Bed
I've tested the code in Python and Pynq.
The test loads a value to each memory location, and then automatically validates integrity.
Load bitstream
from pynq import Overlay
overlay = Overlay("memory_ram.bit")
Generate the GPIO API for Enable and Write Enable
# write enable and enable are GPIO pins
from pynq import GPIO
we = GPIO(GPIO.get_gpio_pin(0), 'out')
en = GPIO(GPIO.get_gpio_pin(1), 'out')
def disable():
    en.write(0)
    we.write(0)
    return
def write_enable():
    en.write(1)
    we.write(1)
    return
def read_enable():
    en.write(1)
    we.write(0)
    return
Generate the AXI API for Address and Data
from pynq import MMIO
memory_address = overlay.ip_dict['axi_gpio_memory_ram']['phys_addr']
RANGE = 4
memory_register = MMIO(memory_address, RANGE)
def memory_write(address, data):
    # must disable until register is set
    disable()
    # mask data for 12 bits maximum
    memory_register.write(0,address << 12 | (data & 0X0FFF))
    write_enable()
    disable()
def memory_read(address):
    disable()
    memory_register.write(0,address << 12)
    read_enable()
    data = memory_register.read()
    disable()
    return data
Execute unit tests
This section shows how you can fully automate the validation of a design.
This is useful while developing the FPGA blocks, but also as regression test when you change it.
Every address is filled with a value that can be checked later on.
For the tests, you can choose to test every address, or to spot check every so much positions. I'm testing every 128th address position.
The border conditions, the first and last memory address, are always tested.
address_count = 1024
test_granularity = 128
test_errors = 0
def change_data(data):
    return 2 * data
def test_data(address, data):
    success = (change_data(address) == data)
    if(success):
        print(f'memory at address {address:04}: OK')
        return True
    else:
        print(f'memory at address {address:04}: ERROR')
        return False
disable()
# fill all addresses with a different value
print(f'fill all {address_count} addresses with a different value')
for i in range(0, address_count):
    memory_write(i, change_data(i))
print(f'validate every {test_granularity} address')
print('')
print('visual checks:')
print('==============')
# read a subset back
print('first read')
for i in range(0, address_count, test_granularity):
    print(f'memory at address {i:04}: {memory_read(i):04}')
print('second read to confirm read isn\'t destructive')
# check if no bogus writes
print('')
print('unit test')
print('=========')
# check if data matches expectation
    if not (test_data(i,memory_read(i))):
        test_errors = test_errors + 1
print('test border cases first and last address always')
if not (test_data(0,memory_read(0))):
if not (test_data(address_count-1,memory_read(address_count-1))):
if test_errors > 0:
    print(f'test failed {test_errors} times')
else:
    print('all tests passed')
The test report:
fill all 1024 addresses with a different value
validate every 128 address
visual checks:
first read
memory at address 0000: 0000
memory at address 0128: 0256
memory at address 0256: 0512
memory at address 0384: 0768
memory at address 0512: 1024
memory at address 0640: 1280
memory at address 0768: 1536
memory at address 0896: 1792
second read to confirm read isn't destructive
unit test
memory at address 0000: OK
memory at address 0128: OK
memory at address 0256: OK
memory at address 0384: OK
memory at address 0512: OK
memory at address 0640: OK
memory at address 0768: OK
memory at address 0896: OK
memory at address 1023: OK
all tests passed
The Vivado 2020.1 project and Jupyter code are attached.
Pynq - Zync - Vivado series
Add Pynq-Z2 board to Vivado
Learning Xilinx Zynq: port a Spartan 6 PWM example to Pynq
Learning Xilinx Zynq: use AXI with a VHDL example in Pynq
VHDL PWM generator with dead time: the design
Learning Xilinx Zynq: use AXI and MMIO with a VHDL example in Pynq
Learning Xilinx Zynq: port Rotary Decoder from Spartan 6 to Vivado and PYNQ
Learning Xilinx Zynq: FPGA based PWM generator with scroll wheel control
Learning Xilinx Zynq: a Quadrature Oscillator - 2 implementations
Learning Xilinx Zynq: a Quadrature Oscillator - variable frequency
Learning Xilinx Zynq: Hardware Accelerated Software
Automate Repeatable Steps in Vivado
Learning Xilinx Zynq: Try to make my own Accelerated OpenCV Function - 1: Vitis HLS
Learning Xilinx Zynq: Try to make my own Accelerated OpenCV Function - 2: Vivado Block Design
Learning Xilinx Zynq: Logic Gates in Vivado
Learning Xilinx Zynq: Interrupt ARM from FPGA fabric
Learning Xilinx Zynq: reuse and combine components to build a multiplexer
PYNQ version 2.7 (Austin) is released
PYNQ and Zynq: the Vitis HLS Accelerator with DMA training - Part 1: Turn C++ code into an FPGA IP
PYNQ and Zynq: the Vitis HLS Accelerator with DMA training - Part 2: Add the Accelerated IP to a Vivado design
PYNQ and Zynq: the Vitis HLS Accelerator with DMA training - Part 3: Use the Hardware Accelerated Code in Software
PYNQ and Zynq: the Vitis HLS Accelerator with DMA training - Deep Dive: the data streams between Accelerator IP and ARM processors
Use the ZYNQ XADC with DMA part 1: bare metal
Use the ZYNQ XADC with DMA part 2: get and show samples in PYNQ
VHDL: Convert a Fixed Module into a Generic Module for Reuse
memory_ram.zip
memory_ram_jupyter.zip
    Jan Cumps over 4 years ago
    I'm going to try and adapt this example for DMA use, to exchange data between the RAM and the Zynq's DRAM.
    It could be a portability gateway. Vendor specific logic to get the RAM written and read from Compute side. Generic VHDL from RAM to other FPGA IP.
    Jan Cumps over 4 years ago in reply to Jan Cumps
    ... first, as preparation: VHDL: Convert a Fixed Module into a Generic Module for Reuse.
    adapting the design so that I can make any size of memory with the same implementation.
