FPGA
FPGA
Blog Add Pynq-Z2 board to Vivado
  • Date Created: 31 May 2021 7:47 PM Date Created
  • Views 39243 views
  • Likes 13 likes
  • Comments 40 comments
  • zynq
  • xilinx
  • jupyter
  • fpga
  • vivado
  • pynq
31 May 2021
Instructions on how to add the Pynq-Z2Pynq-Z2 board to Vivado.
This allows you to create projects and custom FPGA bit streams for it.
image source: customer action video after completing the instruction video of Cathal McCabe listed at the end of this post.
In the Vivado project creation wizard, there is a possibility to prime your design from a board definition.
You don't need to find out what the exact FPGA is, and what hardware is available.
There are more project preparation tools. Constraint files and TCL files that fully define the board with all possibilities enabled.
This post focuses on the board definition.
Get the board file
The files listed on pync.io are not available. I found them here.
Install and register the board in Vivado
Then there are two options.
  • (deprecated) Directly put the files in the Vivado boards folder: <Xilinx installation directory>\Vivado\<version>\data\boards\board_files.
  • Or (preferred)  put them at a location you decide, and add a line to the Vivado init file, %APPDATA%/Xilinx/Vivado/init.tcl (create it if it does not exist)
    set_param board.repoPaths [list "D:/Xilinx/pynq-z2/A.0"]
I used the 2nd option. You have to restart the editor.
The result is that you can now create projects that have the right FPGA info for the Pynq-Z2:
My goal for this week is to replicate this exercise from Cathal McCabe from the Pynq community:
I attached the project to this post, and the jupyter notebook.
I changed some things:
32 bit GPIO instead of 64
A reset input for the Johnson Counter module
Translated the Verilog Counter code to VHDL.
Pynq - Zync - Vivado series
Learning Xilinx Zynq: port a Spartan 6 PWM example to Pynq
Learning Xilinx Zynq: use AXI with a VHDL example in Pynq
VHDL PWM generator with dead time: the design
Learning Xilinx Zynq: use AXI and MMIO with a VHDL example in Pynq
Learning Xilinx Zynq: port Rotary Decoder from Spartan 6 to Vivado and PYNQ
Learning Xilinx Zynq: FPGA based PWM generator with scroll wheel control
Learning Xilinx Zynq: use RAM design for Altera Cyclone on Vivado and PYNQ
Learning Xilinx Zynq: a Quadrature Oscillator - 2 implementations
Learning Xilinx Zynq: a Quadrature Oscillator - variable frequency
Learning Xilinx Zynq: Hardware Accelerated Software
Automate Repeatable Steps in Vivado
Learning Xilinx Zynq: Try to make my own Accelerated OpenCV Function - 1: Vitis HLS
Learning Xilinx Zynq: Try to make my own Accelerated OpenCV Function - 2: Vivado Block Design
Learning Xilinx Zynq: Logic Gates in Vivado
Learning Xilinx Zynq: Interrupt ARM from FPGA fabric
Learning Xilinx Zynq: reuse and combine components to build a multiplexer
PYNQ version 2.7 (Austin) is released
PYNQ and Zynq: the Vitis HLS Accelerator with DMA training - Part 1: Turn C++ code into an FPGA IP
PYNQ and Zynq: the Vitis HLS Accelerator with DMA training - Part 2: Add the Accelerated IP to a Vivado design
PYNQ and Zynq: the Vitis HLS Accelerator with DMA training - Part 3: Use the Hardware Accelerated Code in Software
PYNQ and Zynq: the Vitis HLS Accelerator with DMA training - Deep Dive: the data streams between Accelerator IP and ARM processors
Use the ZYNQ XADC with DMA part 1: bare metal
Use the ZYNQ XADC with DMA part 2: get and show samples in PYNQ
VHDL: Convert a Fixed Module into a Generic Module for Reuse
johnson_counter.zip
johnson_counter_jupyter_notebook.zip
    Jan Cumps over 5 years ago +2
    So far so good ...
  • narrucmot
    narrucmot over 5 years ago in reply to Jan Cumps +2
    Very cool! Glad you got this working! --Tom
  • drozwood90
    drozwood90 over 5 years ago in reply to Jan Cumps +2
    Hi Jan, Can I offer a suggestion? Please bold " set_param board.repoPaths [list "D:/Xilinx/pynq-z2/A.0"]" That is something that so many people miss. That is really the proper way that Xilinx suggests…
  • drozwood90
    Hi Jan,
    Can I offer a suggestion?  Please bold "set_param board.repoPaths [list "D:/Xilinx/pynq-z2/A.0"]"
    That is something that so many people miss.  That is really the proper way that Xilinx suggests as they are moving away from the "drop files into the boards folder"
    I'm happy you were able to get this to work!
    --Dan
    Jan Cumps over 5 years ago in reply to narrucmot
    Thank you. My first baby steps with the Zynq family and Vivado.
    I used ISE and Spartan 6 before. That helps to understand the FPGA part (or at least recognise some concepts image ).
    First impressions are good.
  • narrucmot
    --Tom
    Jan Cumps over 5 years ago in reply to Jan Cumps
    It works. Custom bitstream running on the board, created in Vivado, named johnson_counter.bit.
    Result:
    So far so good ...
