Project14
Project14
Documents Project14 | Project Blogs and Project Videos: 2017
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Date Created: 21 Jan 2020 4:28 AM Date Created
  • Last Updated Last Updated: 15 Apr 2020 11:25 PM
  • Views 2285 views
Project Blog and Project Video Archive
Project14  | Monthly Themes | Monthly Poll
Project Archive: Arduino | Pi / micro:bit / BB | Hardware / Software | Categories | 2020  | 2019 | 2018 | 2017
April 2017:  Techno Toys
  • Bob_007 by rsc
    • Bob_007
  • A Duck with a New Purpose by armour999
  • Xylophonomatic by tech_nut81
    • AutoAvoidancePrototype
    • xylophonomatic semi-fail
  • DollaS Dancer by Molham
    • DollaS Dancer
    • DollaS Dancer
  • Sparky the Power Chick - update by dougw
    • Sparky the Power Chick 2
  • This little bug has a bug by idanre1
    • Little bug has a bug
May 2017:  Geeky Gadgets
  • Geeky Dalek Project by lahey
  • Geeked Out Business Cards by dougw
    • BusinessCardPOC1
  • Build your own Torch/Flashlight! by shabaz
  • Project Portfolio Badge by fvan
June 2017:  Going Green
  • IOT Irrigation valve by idanre1
    • Breadboard - IOT Irrigation system
    • Assembly - IOT Irrigation system
  • Chicken Coop Livestream by fvan
July 2017:  DIY Test Equipment
  • 0-24V 8A -5V +5V 2A Power Supply Made with Affordable Adjust DC-DC Converters by guillaume9433
  • DIY Test Equipment: Mini Air Jet by rsc
    • HotFilm
  • Mini Logic Probe with display by Workshopshed
  • DIY Test Equipment: The ByEar 2000 - A Logic Probe by jc2048
    • ByEar-2000
  • USB Programmable (electronic DC load) Test Equipment by Jan Cumps
  • DIY Test Equipment: Ears and Tears 2020 (A Logic Probe) by koudelad
  • Process Duration Timer  Blog 1 (The Timer) by jw0752
    • Clock Suspension POC Test
  • Process Duration Timer Part 2 (Power Supply)
  • Process Duration Timer Part 3 (Interfaces)
  • Process Duration Timer Part (4) The Brain and Proof of Concept
    • Process Duration Timer POC
  • Process Duration Timer (Final Chapter) Assembly and Testing
    • First Test of Process Duration Timer
    • PDT timing the discharge of a 350uF Cap
  • Multi-Ref Mk. II by hlipka
  • Programmable Electronic Load: Dynamic Behaviour: Part 1 Overview by jc2048
  • Programmable Electronic Load: Dynamic Behaviour: Part 2 The Servo Loop
  • Programmable Electronic Load: Dynamic Behaviour: Part 3 Effect of Output Inductance
  • Programmable Electronic Load: Dynamic Behaviour: Part 4 Effect of Output Voltage Change
  • Programmable Electronic Load: Dynamic Behaviour: Part 5 Stability
  • Raspberry PI - Ohmmeter by sherbieny
  • Building a Fluxgate Magnetometer based Current Probe by shabaz
  • DIY Test Equipment: The Di-o-Matic, a Simple Diode Tester [Arduino] by jc2048
  • Vintage 555 - A general-purpose button debouncer by balearicdynamics
    • Vintage 555
  • TLE94112 Interactive Testing Platform by balearicdynamics
  • 3D Printer Filament Automatic Dispenser for Arduino - #1 Design and Hardware
  • 3D Printer Filament Automatic Dispenser for Arduino - #2 Connection and Software
  • Cyclops-1000: An Electronic Eye for Rotational Speed Measurement by shabaz
    • Cyclops-1000: An electronic eye / tachometer project for rotational speed measurement
  • Arduino oscilloscope - DIY entry device by idanre1
    • Girinoscope 2.0
    • Girinoscope 2.0 probe lm358n
  • Project14's DIY Test Equipment: DIY Constant Current Load by ipv1
    • DIY DC Constant Current Load
August 2017: Solar Powered Yard Gadget
  • Tilt Solar Light by carmelito
    • Tilt Solar Table Light
  • Building a Solar Charger by shabaz
    • Building a Solar Powered Battery Charger
September 2017: Wacky Automation Devices
  • Purple Panic Button by dougw
    • Purple Panic Button Build
    • Purple Panic
  • Automated Tea Dunker by carmelito
    • Automated Tea Dunker (created for Project14 - Wacky Automation Device)
  • Voice activated torch using a Rube Goldberg Machine by Workshopshed
    • Electro-mechanical Rube Goldberg Machine
October 2017: Simple Electronic Repairs
  • Train Repair by Workshopshed
    • Toy Train Repaired
  • Non-Electrical to Electrial issue: Battery booster pack repair. by gam3t3ch
    • Non-Electrical to Electrial issue: Battery booster pack repair. Part 1
    • Non-Electrical to Electrial issue: Battery booster pack repair. Part 2
    • Non-Electrical to Electrial issue: Battery booster pack repair. Part 3
    • Non-Electrical to Electrial issue: Battery booster pack repair. Part 4
    • Non-Electrical to Electrial issue: Battery booster pack repair. Part 5
  • Repair of tone control circuit in old transistor radio by kk99
    • ITT Schaub-Lorenz Touring International 103
    • ITT Schaub-Lorenz Touring International 103 (FM)
  • Potentiometer Repair by rsc
  • Fixing R2D2's Brains by Sean_Miller
    • Troubleshooting PCB Power Issues
  • 1970's Sears 8 Track Repair by gam3t3ch
    • 1970s Sears 8 track repair part 1
  • Repair of a CNG boiler control board by koudelad
November 2017:  Cool LED Display
  • Traffic Light Controller "from the clouds" v0.1 by koudelad
    • Traffic controller from the clouds
  • Slot cars starting lights "from the clouds" v0.1
    • F1 style starting lights
    • MotoGP style starting lights
  • Beer Tap by mcb1
    • Beer Tap
  • Project Elf House- Complete by beagles
    • Project Elf House - Complete
  • Project Elf House
    • Project Elf House
  • Project Elf House update 1
  • Cool LED Displays: Boost That LED! by jc2048
  • Scanning Laser Project by rsc
    • Laser Scanner
  • Hello My Name is...In Lights! (with instructional video and all required files!) by makethingstoday
    • Arduino Powered RGB LED Name Tag
  • AR-Drone Arduino with programmable RGB LED string by rsc
    • AR-Drone Arduino Programmable LED string
  • 3D matrix display by uddin
    • 3D matrix display
  • BrightH2O light! by julior
    • Night Ride
  • Issey Miyake Bao Bao Bag Concept By Kimbab by kimpritzker
    • ISSEY MIYAKE CONCEPTUAL BAG by KIMBAB
  • Pixel Blast by kimpritzker
    • Pixel Blast
  • Cubik Lamp by kimpritzker
    • LED Rubik Cube
  • Mini LED Christmas Tree by carmelito
    • Mini LED Tree
  • DIY LED Ferris Wheel by dixonselvan
    • DIY LED Ferris Wheel | Frame Making | Element14 - Project14
    • DIY LED Ferris Wheel | Electronics | Element14 - Project14
    • DIY LED Ferris Wheel | In Darkness | Element14 - Project14
  • Simple thermometer by kk99
  • Infrared thermometer by kk99
    • Pyrometer
  • Cotton LED star with Digispark module by kk99
    • Cotton LED star
  • Snake Lamp by kimpritzker
    • Snake game
  • Archery timer display by WarrenW
    • Archery Timer Display
December 2017:  The Holiday Special
  • FLiP Connected X-Mas Ornament by jomoenginer
    • DIY Bluetooth Connected X-Mas Ornament
  • FLiP Connected X-Mas Ornament part II
    • DIY Bluetooth Connected X-Mas Ornament part II
    • Parallax Propeller Multi Cog Example
  • FLiP Connected X-Mas Ornament part III - complete
  • Infinity Living Christmas Wreath by dwinhold
    • The Holiday Special
  • Christmas Vacation Project - Building a Clap Switch Light by jw0752
  • The Clausometer Christmas Spirit Meter by ntewinkel
    • Clausometer Rising
    • Clausometer at 100%
  • Gravity Assisted Blinking Coin Cell Christmas Tree by fmilburn
  • BrightH2O light!
  • LED fade in/out effect
  • Desktop Christmas Tree by jofas
    • final demo
  • Pi OLED Holiday Greeting by ninjatrent
    • Adafruit Pi OLED
  • Project Elf House
  • Stormtrooper Pi Radio by ninjatrent
    • Stormtrooper Pi Radio - White Noise Test
    • Stormtrooper Pi Radio - Voice Test
    • Stormtrooper Pi Radio - Speech Synthesis Test with Festival
    • Stormtrooper Pi Radio - Streaming Music Test
  • Trent's Smart Tree by ninjatrent
    • Amazon Echo Voice Controlled Smart Christmas Tree
  • XMAS lights by Workshopshed
Contributors:  rsc, armour999, tech_nut81,  Molham,  dougw,  idanre1,  lahey,  shabaz,  fvan,  guillaume9433,  Workshopshed,  jc2048,  Jan Cumps,  koudelad,  jw0752,  hlipka,  sherbieny, balearicdynamics,  ipv1, carmelito,  kk99,  Sean_Miller,  gam3t3ch, mcb1,  beagles,  makethingstoday,  uddin,  julior,  kimpritzker,  dixonselvan,  WarrenW,  jomoenginer,  dwinhold,  ntewinkel,  fmilburn,  jofas,  ninjatrent
