Project14
Project14
Documents Project14 | Project Blogs and Project Videos: 2018
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Date Created: 20 Jan 2020 3:47 AM Date Created
  • Last Updated Last Updated: 15 Apr 2020 11:21 PM
  • Views 2113 views
Project Blog and Project Video Archive
Project14 | Monthly Themes | Monthly Poll
Project Archive: Arduino | Pi / micro:bit / BB | Hardware / Software | Categories | 2020 | 2019 | 2018 | 2017
January 2018: Portable Electronics Kit
  • The Magic Tool Kit by dougw
    • HandTools
    • BuildingBlocks
    • MagicTool
  • The Arduino Starter Kit Upgraded Case by gam3t3ch
  • My late (and incomplete) entry for the Portable Electronics Kit - The Pi-IDE (Pie-Eyed). by the-dubster
    • Portable Electronics Kit
  • The gradual progression of my Pi-IDE - my portable electronics / dev kit.
  • The gradual progression of my Pi-IDE - my portable electronics / dev kit.  Minor update.
  • More gradual progression towards my Pi-IDE - Portable Electronics / Dev Kit
  • The Penultimate Dev Kit PSU update (probably)!
  • BoneCommander - A Ruggedized BeagleBone Linux Computer by ninjatrent
  • PERMA-PROTO:  A Portable Prototyping System Built to Last by fmilburn
    • MSP430G2553 Proto Board and Enclosure
  • Babbages Baggage by Workshopshed
    • Babbage's Baggage
  • Control an relay from web server using NodeMCU by kk99
  • EE-CARD: A Portable Electronics Project Kit by shabaz
February 2018: Mixing Electronics & Water
  • Salt water cell by kk99
    • Salt water cell
  • (Semi)Automated Plant Irrigation System by urkraft
  • HOPPY - An intelligent Raspberry Pi Irrigation System by 14rhb
    • HOPPY - normal operation
    • HOPPY - manual override
    • Manual Override of 'Valve'
    • HOPPY - test mode
  • Remote (Water) Temperature Monitoring by ntewinkel
    • ESP-01 Data Logger
  • Long Shower = Candle Power by Sean_Miller
    • Deep Dive: KiCAD Full Tutorial - Design an ESP8266 Programmer
    • Deep Dive: ESP8266 Programmer Perfboard Circuit Board
    • WiFi Shower Timer to Flip the Lights using IFTTT.com
  • Social Plant Survival Kit by msimon
    • Water & Electronics
    • Social Plant Watering Test
March 2018: Robots with Wheels
  • 300g BOT by mcb1
    • 300g BOT
  • RoboBobLet #2 : The Basic Chassis by dubbie
    • Basic Chassis of the Four Wheel Drive Robot
  • RoboBobLet#3
    • Continuous Servo Motor Speed Measurement
  • RoboBobLet #4 BlueTooth
    • Checking the HC06 Bluetooth Connections to a Smart Phone
    • Testing RoboBobLet with the Bluetooth Connection
  • RoboBobLet #5 : A Laser RangeFinder
  • RoboBobLet #6 The Scanning Laser Rangefinder
    • A Scanning Laser Distance Sensor
  • RoboBobLet #7 : Adding a Pixy Camera
    • Connecting a Pixy Camera to an Arduino Nano
  • RoboBobLet#8 : The Final Assembly
    • RoboBobLet : Final Assembly
  • HaloBOT ver 2.0 by mcb1
    • HaloBOT ver 2.0
  • Not RoboBobLet #1 by dubbie
    • BigTrak Ranger Hack Medium
  • HaloBOT by mcb1
    • HaloBOT
  • A lightweight robot platform by Workshopshed
  • PWHBot #1: Introduction by jomoenginer
    • PWHBot Overview
  • PWHBot #2: Table Top Challenge 1
    • TI TM4C123GXL PeeWee Bot
  • Unreal. Resistance is Futile
  • Robots with Wheels - CupRobot by carmelito
    • Project14- Robots with Wheels - CupRobot
  • From line following to indoor Mapping by shwetankv007
    • Robot_load_test with turnigy remote
    • UDV lfr test
    • rviz odometry robot
    • gazebo simmulation
  • Cardboard Robot With Wheels: A BBC micro:bit STEM project by balearicdynamics
    • Robot Wheels
  • The Making of R2D2 - The Force on Wheels by Sean_Miller
    • Outer Front Skin
    • R2 Leg Building Pictorial
    • Foot Drive First Test
    • You know you are a geek if...
    • How to Make a Printed Circuit Board (PCB) to Control Star Wars R2D2 feat. Shia Labeouf-Just Do It!
    • R2D2 Autonomous First Steps
    • R2D2 Idle Animations
  • The Lino Project with Arduino Mega 2560: Interrupts and Motors
April 2018: Open Arduino
  • Arduino SD Card Audio Player & LM386 Audio Amplifier board by gam3t3ch
    • Arduino SD Card & LM386 Audio Dev board - Project14
  • Arduino in Test Instrumentation - Intro: SCPI Programmable Switch by Jan Cumps
    • Arduino in Test Instrumentation - LabVIEW Programmable Switch
  • Arduino in Test Instrumentation - Part 1: SCPI Lib
  • Arduino in Test Instrumentation - Part 2: Firmware
  • Arduino in Test Instrumentation - Part 3a: LabVIEW Driver Intitialisation Block
  • Arduino in Test Instrumentation - Part 3b: LabVIEW Driver Switch Control Block
  • Arduino in Test Instrumentation - Part 3c: LabVIEW Driver Read Status Block
  • Arduino in Test Instrumentation - Outro: LabVIEW Example
  • Indicator Tester by mcb1
    • Brake/Indicator Tester
  • Arduino, Temperature, LCD and more by mcb1
  • Arduino-controlled FLIR DUO MPU-9250 Stabilized Servo Gimbal by rsc
    • Stabilized Servo Gimbal
  • Intelligent Hall Light by mcb1
  • Travelling Dolly by mcb1
    • MX2-IGUS slider
    • Travelling Dolly
  • Edge Lit signs by mcb1
    • Edge Lit Signs
  • HomeMinder by mcb1
  • Retirement Present by mcb1
  • Intermittant Wipers by mcb1
  • HaloBOT
  • A more Intelligent Idiot Light by mcb1
    • Intelligent Idiot Light
  • Pololu Balboa (balancing robot) by mcb1
  • Wordclock by mcb1
    • Word Clock
  • Vehicle Fan Controller by mcb1
  • HaloBOT ver 2.0
  • Newtonian Arduino based telescope by netpack
  • Macrobinocular Mk7150 by 14rhb
  • Remote Temperature Sender by mcb1
    • Remote Temperature Sensing
  • Robot balances and translates on a ball using Arduino. by thachdovan
    • Ballbot - Initial tests
  • Celebrating Arduino with a Torch Relay! by ntewinkel
    • Arduino Torch Relay
  • Weather Cloud Clock by carmelito
    • Weather Cloud Clock - using Arduino MKR1000
  • Marshmallow Eating Poster Makes Arduino Roaster - Project 14 Birthday Blog by Sean_Miller
    • Marshmallow Rotisserie
  • The blind's man clock by idanre1
  • Exploding Kittens Soundboard by fvan
    • Exploding Kittens Soundboard using Touch Board
  • I See in my Magic Ball...Someone is at the Front Door! by makethingstoday
    • Glowing Notification Ball for Home Assistant
  • Cycloboat by Molham
    • Cycloboat
  • LS Cubed: Little Sister Security System by fmilburn
    • ESP8266 Sensor Demonstration using ESP-NOW
    • Real world test of RCWL-0516
  • Arduino and ESP-01 based irrigation system by urkraft
    • Arduino Uno and ESP-01 based Semi-automated Irrigation System
  • Arduino Powered MSE-6 (Mouse Droid) by jomoenginer
  • Arduino Powered MSE-6 (Mouse Droid) - Arduino Yun UI
    • MSE-6 Mouse Droid Arduino Yun UI
  • Arduino Powered MSE-6 (Mouse Droid) - Arduino Uno and FreeRTOS
    • FreeRTOS running on a Arduino UNO
  • Arduino Powered MSE-6 (Mouse Droid) - Droid in Action
    • MSE-6 Mouse Droid Inside Look
    • MSE-6 Mouse Droid running
  • Arduino Powered MSE-6 (Mouse Droid) – Arduino Code
  • Unreal. Resistance is Futile by balearicdynamics
    • Unreal. Resistance is futile
    • Rose lighting effect
  • Cyber Chicklet by dougw
    • CyberChicklet2
    • DestinyButton
    • HappyArduinoDay
    • HIDconglomerate
  • NTSC/PAL Video Display Shield by wolfgangfriedrich
    • BoingBall animation on Arduino Video Shield VS23S010D
  • Sensortile - programming with Arduino ! by armour999
    • SenorTile and Arduino
  • BirthdaySpecial: MEGATRON32 - AVR Dev Board by sunnyiut
    • Birthday Special: MEGATRON32 - AVR Development Board Demonstration
  • 3D Printer Filament Automatic Dispenser for Arduino - #1 Design and Hardware by balearicdynamics
    • 3D Printer Filament Motor Dispenser for Arduino
  • 3D Printer Filament Automatic Dispenser for Arduino - #2 Connection and Software
    • 3D Printer Filament Motor In Action
  • ArduTrx - a 2-meter-band ham radio transceiver with Arduino by bernhardmayer
  • The Lino Project with Arduino Mega 2560: Interrupts and Motors by balearicdynamics
    • Preformatrice - Cabochonatrice - Artigianato Pietredure di Pavia Cesare
    • Lino 1.0 Prototype in action
  • IR intervalometer for camera by kk99
    • IR intervalometer
April 2018: Simple Music Maker
  • Simple electronic musical instrument by kk99
    • Simple musical instrument
  • Beaglebone plays the blues by Workshopshed
    • BeagleBone Blue Electro-Mechanical Glockenspiel
  • Old fashioned Japanese Music Box by Workshopshed
    • Music Box
  • A Simple Arduino Music Box by jc2048
    • Simple Arduino Music Box
    • Simple Arduino Music Box - March from a certain science fiction film
  • Simple Arduino Music Box: Voices
    • Simple Arduino Music Box: Voices - Example 1
    • Simple Arduino Music Box: Voices - Example 2
  • Simple Arduino Music Box: Chords
    • Simple Arduino Music Box - Chord demo
  • Simple Arduino Music Box: Envelopes
    • Arduino Music Box - Envelope Generation
  • Simple Arduino Music Box: Chimes
    • Arduino Music Box: Chimes
  • 555cc
  • Tube headphone amplifier by kk99
  • Homemade Electric Guitar by dwinhold
    • Electric Guitar
  • Dum-De-Dum, the Cardboard Drum! by balearicdynamics
    • DumDeDum the Cardboard Drum
  • The IOT Wind Chimes by fmilburn
    • IOT Wind Chimes
May 2018: Smart Alarm Clock
  • Object Sensing Clock by guycarver
  • Tempus Fugit... Part 1: 1978 a.d. by balearicdynamics
  • Tempus Fugit... Part 2: 2018 a.d.
  • Tempus Fugit... Part 3: micro:bit Interfacing 5V Logic
    • micro:bit Open Collector
  • Tempus Fugit... Part 4: micro:bit 5V SPI
  • Self-adjusting clock with e-display by kk99
June 2018: Movers and Shakers
  • Walky the Biped Robot - The prequel by genebren
  • Walky the Biped Robot - Power pack
  • Walky the Biped Robot - Oops, Walky has an accident!
  • Walky the Biped Robot - A new hope (actually a new body and battery)
  • Walky the Biped Robot - WalkyII gets some eyes.
  • Walky the Biped Robot - WalkyII gets his legs
  • Walky the Biped Robot - WalkyII gets a new brain
  • Walky the Biped Robot - WalkyII is learning to walk again!
    • WalkyII recharging
  • Walky the Biped Robot - WalkyII is learning to walk again! (part 2)
    • Mover and Shakers - WalkyII
  • Walky the Biped Robot - WalkyII the final chapter.
  • Continuous Servo Bot - using Arduino Nano by carmelito
  • Converting an existing effect pedal to operate a second effects unit using a resistive strip sensor. by ipfreely
    • resistive pressure sensor for guitar expression pedal using a tesla plasma coil for the output device
  • Jumbo Servo by Workshopshed
    • Motor Testing
    • Motor Testing 2
July 2018: Solar Power Devices
  • Simple Solar BOT ----Blog 1 by snidhi
  • Simple Solar BOT ----Blog 2
    • Simple Solar BOT Test ---Blog 2
    • Simple Solar BOT ---Blog 2
  • Simple Solar BOT ----Blog 3
    • Powering the Arduino Nano with Solar Panels
  • Simple Solar BOT ----Blog 4
  • Simple Solar BOT Tragedy and Recovery ----Blog 5
    • Gear-less Motor Test in Simple Solar BOT ---Blog 5
    • Gear-less Motors fail --Simple SolarBot 5
    • Simple SolarBoT Video Test with LiPo Battery Power --Blog5
  • Simple Solar BOT ----Finale
    • Simple Solar BOT  ---Finale
  • Solar SPEC Intro by ralphjy
  • Solar SPEC - Design Concept
  • Solar System Description
  • Solar SPEC - Getting Started
  • Solar SPEC - Starting Assembly
  • Solar SPEC - posting data
  • Solar SPEC - Outdoor Test
  • Solar SPEC - updated temperature sensor code
  • Solar SPEC - Completed Assembly
  • Solar SPEC - Challenge Finale
    • Solar SPEC
  • Solar SPEC - What's Next?
  • Home Solar System Performance - Year 1
  • Solar Bubble Blaster by fmilburn
  • Project 'GiraSol' - Oliver Schalles by oliverschalles
    • optical switch and oszi
    • one channel detect by oszi
    • working optos at GiraSol.Box
    • doubleliquid compressed air spray gun
    • silverizing attempt
    • Rotation PD Nano
    • Tilt Pan Griosol
August 2018: Clustered MCUs
  • tinyMonster AIO Robot (part-1) by mahmood.hassan
  • tinyMonster AIO Robot (part-2)
  • tinyMonster AIO Robot (part-3)
  • tinyMonster AIO Robot (part-4)
    • tinyMonster Robot Direction Control using IR Remote
    • tinyMonster Robot Movement control using IR Remote
    • tinyMonster Robot IR Control and Obstacle Detection
    • tinyMonster Robot Data
    • tinyMonster Control through AP without WLAN
    • tinyMonster Robot control using WLAN without Internet
    • tinyMonster Robot both WLAN and AP
    • tinyMoster Robot Control Using WLAN GUI
    • tinyMonster Robot Internet Control
  • tinyMonster AIO Robot (part-5)
  • tinyMonster AIO Robot - RF remote
  • The Dancing Birds by balearicdynamics
    • Dancing Birds
    • Kitronik Android App
    • The Music Puppet
    • Testing the Servos
    • Dancing Birds Servo Test
  • The micro:bit Quartet by jc2048
  • Octopod: Smart Home IOT Project by sakshambhutani
    • Octopod: DIY Smart Home Automation Project
  • IoT Magical Wand by dixonselvan
    • IoT Magical Wand | Controlling relay through IFTTT web requests | Project14
  • Tiny light cluster by Workshopshed
September 2018: Test Instrumentation
  • A Simple DC Electronic load for the experimenter's Shop. by jw0752
    • DC Electronic Load Demo
  • Frequency Counter (Square, Sine or Tri angular) by mahmood.hassan
  • TinyDVM#1 by dubbie
  • TinyDVM#2
    • TinyDVMPart2 Medium
  • TinyDVM#3 : Colour and Final Case
    • TinyDVMPart3
  • TinyDVM#4 : Graphical Display
    • TinyDVM Graphic Display (Part 4)
  • TinyDVM#5 : Web Display of Voltages
  • "No lies" IR Thermometer - part I by koudelad
  • "No lies" IR Thermometer - part II
  • "No lies" IR Thermometer - part III
    • IR thermometer - baby body measurement
    • IR thermometer comparision
    • IR thermometer power consumption
  • "No lies" IR Thermometer - part IV
    • IR thermometer rev. B prototype
  • MinMax - Calibration Box by rsc
    • micro:bit Voltage Output Device
  • Precision analog opto-isolation amplifier using HCNR200/201 by mahmood.hassan
  • tinyMonster - Analog Precision opto-isolator
    • MAX. OUTPUT of tinyMonster Opto Isolator
    • MIN. OUTPUT of tinyMonster Opto Isolator
    • Negative INPUT Blocking - tinyMonster Analog OptoCoupler
    • MAXIMUM OUTPUT limit to 3.0V - tinyMonster Analog Optocoupler
    • 1.5V INPUT TEST - tinyMonster Analog Opto Isolator
    • 1.0V INPUT TEST - tinyMonster Analog Opto Isolator
    • 0.5V INPUT TEST - tinyMonster Analog Opto Isolator
    • 0.1V INPUT TEST - tinyMonster Analog Opto Isolator
    • Final Demo - tinyMonster Analog Opto Isolator with microbit
    • UV and OV indicators - tinyMonster Analog Opto Isolator
  • Voltmeter (>1mV) with user selectable range using Micro:bit (Part-1) by mahmood.hassan
  • Wireless voltage measurement with microbit by kk99
    • BLE Micro:bit voltmeter
  • Project PITS by three-phase
    • MCGG Overcurrent Relay Pickup Test Demonstration
  • Project PITS update
  • Project PITS Soft Latch Circuits
  • Automated Cable Test System .. part 1 by phoenixcomm
  • Automated Cable Test System .. part 2
  • Automated Cable Test System .. part 3
  • Automated Cable Test System .. part 4
  • Automated Cable Test System .. part 5
  • Automated Cable Test System .. part 6
  • Automated Cable Test System .. part 7
  • A Transistor Load by jc2048
    • Project14: A Transistor Load
  • A Transistor Load: How it Works
  • A Transistor Load: Stability
  • A Transistor Load: Stability Part 2
  • Simple resistance measurement with the micro bit and voltage divider by kk99
  • Micro:bit VI Curve Tracer Intro by ralphjy
  • Micro:bit VI Curve Tracer Implementation
    • VI Curve Tracer
  • µBOSS .... Test Instrumentation ... micro:bit by dougw
    • uBOSS1
    • uBOSScharger1
    • uBOSSlevel1
  • Working Prototype of a Kelvin (4-Wire) Milliohm Meter by fmilburn
    • Kelvin (4-Wire) Milliohm Meter
  • micro:bit as Pass / Fail indicator in an automated test setup by Jan Cumps
    • micro:bit as Programmable Pass / Fail Indicator: LabVIEW Integration
    • micro:bit as Programmable Pass / Fail Indicator for automated testing
October 2018: Back to Analog
  • Pseudo random number generator by kk99
    • Three bit pseudo random number generator
  • Hiraga Pre-amp: Build part 1 by phoenixcomm
  • Hiraga PreAmp .. build 2
  • Hiraga PreAmp .. build 2a
  • Hiraga PreAmp .. build 3 Gorilla Brake
  • Hiraga PreAmp .. build 4
  • Hiraga PreAmp .. build 5 - software for a tube amp?
  • Tube Amp on a PCB by dougw
    • PCB TubeAmp
  • CVBoard: new way to play with modular synths by costantinorizzuti
    • CVBoard: Arduino Control Voltage
    • CVBoard: usare un laptop per controllare un pedale analogico
    • CVBoard: nuovi modi creativi di suonare il modulare
  • Pulse Hunter by sunnyiut
    • Pulse Hunter - Photoplethysmography
  • 555 Timer Voltage Inverter by fmilburn
  • LED fade in/out effect by kk99
    • LED fade in/out circuit
    • Cotton Ball Lights fade in/out effect
November 2018: Wearable Tech
  • UV Exposure Badge by Workshopshed
    • Wearable Tech - UV Monitoring
  • 'WatchAble' - The Smart Wear:it Watch by dixonselvan
    • WatchAble | smart wear:it watch | Wearable project
  • Saving Sleep with PocketBeagle by vlasov01
    • pocketbeagle wearable project
  • Smart Shopping Bag --Blog1 by anupash.1002
  • Smart Shopping Bag --Blog2
    • Load Cell 10kg bar sensor with HX711 Amplifier display on LCD and flex LED panel
    • Working with Flex LED Panel
  • Smart Shopping Bag --Final
  • The Thinking Cap by ntewinkel
    • The Thinking CAP!
  • ledog - Light Emitting Dog by 14rhb
    • ledog - the Light Emitting Dog
  • Rewritable Electronic Display Name Tag by snidhi
  • Smart Bluetooth Gloves V1 by milosrasic98
  • Helping Alzeihmer Patients with tech! by vimarsh_
    • Project - Helping Alzeihmer Patients with Tech
December 2018: Merry Boxes & LEDs
  • Empty RGB XMAS Tree by designer2k2
    • DIY xmas tree WS2812 RGB LED Digispark
  • JackBox#1 : Gathering Together Some Bits by dubbie
    • JackBox#1
  • JackBox#2 : Adding the Lid Opening Mechanism
    • JackBox#2
  • JackBox #3 : Opening and Closing the Lid
    • Jack in the Box - Initial Testing of the Lid Opening Mechanism
    • Jack in the Box - Refined Lid Opening
  • JackBox #4 : Some Decoration and LEDs
    • Jack in the Box Decoration
  • JackBox # 5 : Adding Some Festive Sound
    • Jack in the Box : Festive Sound
  • JackBox #6 : The Completed Article
    • Jack in the Box : Final Installment
  • LED Firework Suite - the details by 14rhb
    • LED Fireworks
    • Happy New Year - LED Fireworks
    • RGB Strip Star Effect
    • Roman Candle Effect
  • LED Fireworks - Festive Lights 2018
  • LED Fireworks - Happy New Year
  • The Christmas Joy Spreading Machine by balearicdynamics
    • The backlight test of the city skylight
    • Testing the main gear
    • Rotating light test
  • Connected Christmas Trees by ntewinkel
  • Assembling the Trees
  • Finally! Two Trees Assembled
  • Two Trees by a Tree
    • LED Christmas Trees from kits
  • Connecting the Tree to the Internet
    • Testing the First MQTT Christmas Tree
  • Motion Sensor on Wemos
  • Trees! one with motion sickness...
  • Motion Sensor Issues, continued
    • Motion Sensor Test
    • Motion Sensor Abnormal Triggering
  • The Connected Trees are Working!
    • Xmas Trees connected via MQTT, with push buttons
  • Merry Boxes - A Project Within a Project
  • Connected Christmas Trees - Finished!
    • The Finished Connected Xmas Trees
  • Holiday Lights and Music Festival With Love and Cheer by ipv1
    • Christmas LED and Music Project
  • Holiday Lights and Music Festival With Love and Cheer: Python and Wrapping Presents/Code/Applications
  • Probably the best possible Christmas lights by czmusg3jh56fh0jw&maa
    • Christmas lights 1
    • Element 14 Merry Boxes and LEDs competition entry.
  • Mini Singing Holiday Tree by carmelito
    • Raspberry PI -- Mini Singing Holiday Tree
  • ESP8266 Magic Star Mirror with Alexa by jquest
    • Demo of Magic Star Mirror
  • Santa Incoming Chimney! [SIC] by robertwerner
  • Christmas tree made from WS2812 leds by kk99
    • Christmas tree made from ws2812 leds
    • Christmas tree made from ws2812 leds driven by attiny13
  • Caustic XMAS by neuromodulator
    • Static
    • Dust
    • Dynamic
    • Laser Modulation
    • Caustic Tree
  • Flashy LED Picture Frame by tonydbeck
    • LED Picture Frame
  • Albero di(Gi) Natale by costantinorizzuti
    • Albero digi(Na)tale
  • Christmas Magic aka Advent Calendar on stereoids by archiela
    • Magic Christmas
    • ChrimstaMagicCalendarStart
    • ChristmasMagicOperation
    • ChristmasMagicFinal
  • Automatic christmas bell ringers. by danielw
    • Merry Boxes and LED's
  • Merry Boxes and LED's Software.
  • 2D xmas tree pcb art (components INSIDE the pcb) by designer2k2
    • 2D Platinen Weihnachtsbaum
  • Sparky the Power Chick Levitates - Happy New Year by dougw
    • MagLev1
December 2018: A Question of Scale
  • Jumbo LED by Workshopshed
    • Jumbo LED
  • LED tree by kk99
    • LED tree
  • Building a Miniature 300W Speaker Simulator by shabaz
    • Building a Tiny High Power Dummy Load for Audio Testing
  • Tiny24hourMoBot #1 : Starting by dubbie
  • Tiny24hourMoBot #2 : 5 Hours in
    • Tiny24hourMoBot - Progress in Five Hours
  • Tiny24hourMoBot #3 : 13 hours have passed
    • Tiny24hourMoBot - 13 hours into the 24 hour build
  • Tiny24hourMoBot #4 : The 24 hours is almost up
    • Tiny24hourMoBot - MoBot After 24 Hours
  • Tiny24hourMoBot #5 : Post Script - Making it even Tinier
    • TinyMoBot : Even Tinier
  • TinyMoBot #6 : The Transparent Version
    • TinyMoBot - TinyMoBot with Glass Shell
  • TinyMoBot #7 : Using a LiPo Battery
    • TinyMoBot - Adding a LiPo Battery
  • Mini Gameboy Home Console: The Gamebox DMG Consolizer by nobble
    • VGA Game Boy Classic: GAMEBOX, The DMG Consolizer
  • Remote Home Monitoring with Raspberry Pi and Hologram Nova - Full Instructions by luislabmo
    • Remote Home Monitor with Raspberry Pi and Hologram Nova - Intro
  • Size Matters Not - An R2D2 Story by dougw
    • R2D2a
Contributors: dougw, gam3t3ch, the-dubster, ninjatrent, fmilburn, Workshopshed, kk99, shabaz, urkraft, 14rhb, ntewinkel, Sean_Miller, msimon, mcb1, dubbie, jomoenginer, carmelito, shwetankv007, balearicdynamics, Jan Cumps, rsc, netpack, thachdovan, idanre1, fvan, makethingstoday, Molham, fmilburn, wolfgangfriedrich, armour999, sunnyiut, bernhardmayer, jc2048, dwinhold, guycarver, genebren, ipfreely, snidhi, ralphjy, oliverschalles, mahmood.hassan, sakshambhutani, dixonselvan, jw0752, koudelad, three-phase, phoenixcomm, costantinorizzuti, vlasov01, anupash.1002, milosrasic98, vimarsh_, designer2k2, ipv1 , czmusg3jh56fh0jw&maa, jquest, robertwerner, neuromodulator, tonydbeck, archiela, danielw, nobble, luislabmo
    dubbie over 6 years ago +4
    Ah, RoboBobLet, I remember him well. Regretfully he has sacrificed many parts to later instantiations and is now just a shell of his former self - especially as I dropped him on the floor and broke two…
    Ah, RoboBobLet, I remember him well. Regretfully he has sacrificed many parts to later instantiations and is now just a shell of his former self - especially as I dropped him on the floor and broke two servos. But, I did obtain some new continuous rotation servos so maybe RoboBobLet might live again one day.
    Tiny24hourMoBot still sits on my desk waiting to be finished although, as with RoboBobLet, has had to sacrifice parts (wheels and tires) to later robots (the black line follower)
    Many, many other great projects from other Element14 members that I remember well. 2018 was a good year.
    Dubbie
    Dubbie
